12
返回列表 发新帖
楼主: 活建鬼
[设计鉴赏] 【鬼知道】009 基于Voronoi的屋顶策略
21m
发表于 2012-12-25 11:16:35 | 只看该作者
Voronoi Roof Strategies
The development of a parametric Voronoi structure for a renowned architecture firm Frankfurt
基于voronoi的屋顶策略
著名的建筑事务所法兰克福参数的Voronoi结构的发展
The architectural design strategy for the roof of an existing property from the early days in Frankfurt's West was through the use of a Voronoi structure create a contemporary aesthetics and link them to an architectural nod to the contextual time levels of the genius loci, to a multi-temporary design.
从法兰克福西部早期的一个现有的财产的屋顶的建筑设计战略是通过使用一个基于Voronoi结构创建一个当代美学,并链接到一个前后时间级别的天才基因位点的建筑组合,到多元临时设计。
The task of arch + lab consisted of the triangular surfaces existing, new roof volume provided with a parametric, following the openings and the sizes of the areas, Voronoi structure. Besides the size of the area and the number of cells, it is Voronoi here the position of the under the roof skin lying window openings which generates as a variable parameter is the appearance of the compacted or light cells. The Voronoi should help the new roof an existing property from the early days in Frankfurt's West to contemporary design and architectural references to the contextual levels of time the genius loci, to connect to a multi-temporary design.
arch+实验室的任务包括实现众多三角表面,新的屋顶具有一个参数体积,根据开口和区域的尺寸,基于Voronoi结构。除了的区域的大小和细胞的数量,这里是Voronoi外观的屋顶窗开口的皮肤的位置产生并作为变量参数表现为压实或光的细胞。Voronoi法则应该帮助新的屋顶从早期就在法兰克福西部的现有的物业到一个现代设计和引用建筑前后时间级别的天才基因位点的建筑,连接到一个多元临时设计。
Extensive testing with a lot of variables and alternative roof designs were by the parametric structure of the model in a short time to achieve the best possible result. In contrast to a manual construction of models with different characteristics, which for a long time had been used.
有很多的变量和替代屋顶设计的模型广泛的测试,通过参数化结构在很短的时间以达到最佳的结果。与具有不同特性的已经使用很长一段时间的手动建筑模型相反。
不是很准,略作参考
22m
发表于 2013-1-23 11:48:13 | 只看该作者
学海无涯,无涯
23m
发表于 2013-6-2 19:22:08 | 只看该作者
很强的啊
24m
发表于 2014-4-22 23:24:37 | 只看该作者
膜拜楼主~~~~~~
25m
发表于 2014-12-4 12:33:06 | 只看该作者
很高端的啊 能发个运算器 学习学习吗
26m
发表于 2016-7-9 19:05:36 | 只看该作者
赞一个。。。。。。。。
27m
发表于 2016-7-10 19:28:34 | 只看该作者
28m
发表于 2016-7-10 19:29:38 | 只看该作者
wangjunxiong 发表于 2012-9-12 13:53
最近在搞这个东西,真TMD难!
屋顶的分格是按建筑模数来分的吗?求指教啊?
29m
发表于 2016-7-10 19:32:02 | 只看该作者
wangjunxiong 发表于 2012-9-13 08:06
我都朦胧了,貌似什么都不是。就一在建工程,但现场没按设计的数据施工,导致后期无限大的现场测量工作 ...
这个工程能够按图施工吗,最后需要手工性优化板材吗?
30m
发表于 2016-7-12 19:59:26 | 只看该作者
好好学习一下咯~
31m
发表于 2016-7-14 10:30:37 | 只看该作者
学海无涯,无涯
GMT+8, 2026-7-1 21:47 , Processed in 0.659005 second(s), 22 queries , Gzip On.
