查看: 40872|回复: 24
[设计鉴赏] 迪拜Za abeel公园观测塔
发表于 2010-3-27 10:19:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2010-3-27 11:37:12 | 只看该作者
链接好像出错了,你再看看。
发表于 2010-3-27 12:21:50 | 只看该作者
在面页上的一幅小图上,点击进去就看得到了。
发表于 2010-3-27 12:53:30 | 只看该作者
本帖最后由 panhao1 于 2010-3-27 12:55 编辑 先 预览一下 貌似不错的项目 详情见LZ给的网址 Dubai ZPO Tower
    Dubai UAE
  • 2009
The site plan for the Za'abeel Park Observation (ZPO) Tower is organized according to a traditional Islamic geometric pattern found in the regions' decorative arts. At the scale of the plaza, this pattern takes the form of the granite paving, lines of grass, flowers and trees, and a ribbon of water that draws one in and through the base of the ZPO Tower. This same pattern at a larger scale delineates four distinct landforms around the base of the tower, creating different pathways and approaches to the base as well as providing required program spaces for parking, conference center, children's library and service areas. A flexible conference center for one hundred persons is located along a pathway to the North of the tower, with access to the lake, Za'abeel Park and a garage located within a second landform. A Children's Library is located in a smaller landform adjacent to the main tower entry, and a fourth landform shielding the site from highway traffic is provided for mechanical and service spaces. The Islamic pattern is rendered in different grasses and plantings at a larger scale over these landforms, with the intention that they are accessible for the public to climb upon and to sit to watch the crowds or the lights of the tower above. The landforms serve to both frame and guide the activity around the entry points to the tower and also to create a gradual transition between the scale of the ZPO Tower and the larger Za'abeel Park as it extends to the North and West. The intention is for the ZPO Tower to be built as a net zero energy tower. Several hundred square meters of thin film photovoltaic solar will clad the horizontal planes of the upper petal roofs and the Southern, Western and Eastern exposures of the tower. The main program areas are located beneath landforms with green roofs to reduce solar gain. Geothermal cooling and ventilation will serve these program areas. All the water used on the site will be recycled, and the majority of the building materials will come from recycled sources. Estimates are that the solar energy alone will generate enough electricity to illuminate and power the building. The ZPO Tower has been developed in plan, sections and elevation with reference to both the Islamic pattern developed in the site planning and the geometric qualities of certain desert flowers native to the region. There are six tubes set in a 30m diameter, with three inner tubes and three outer tubes. The inner tubes comprise the circulation system for the tower; one containing the elevators, one containing an open stair and one containing an enclosed, fire-rated emergency egress stair. These three inner tubes are shaped according to their function and also to provide lateral structural support for the dynamic configuration of the three outer tubes. The three outer tubes are articulated to describe a 270-degree rotation around an invisible cylinder defined by the original Islamic pattern. At the base the tubes open and expand into “petals” of open air steel structure with a continuous cladding of monocrystalline solar panels at the Southern and Western exposures. As the three outer tubes rise they begin to open and expand into larger petals that cantilever out 70m in each direction at the top of the tower. Inside these upper petals are dramatic spaces that contain a café and six interconnected indoor and outdoor observation deck areas on two levels. The structure of this tower is comprised of a steel diagrid system, interlaced with additional steel members that follow the lines from the pattern at plaza level of the site. The intention is that the structural pattern, derived from traditional Islamic patterns, becomes the expression of the ZPO Tower. At times this structural pattern may be more open as building loads are dispersed, and at times they may be so dense that they resemble the traditional mashrabiyya screens found in the regional architecture.
参与人数 1照度 +20 收起 理由
yanhui314 + 20 好版主
发表于 2010-3-27 16:57:40 | 只看该作者
好美啊~~~~~呵呵 大家练习练习吧啊~
发表于 2010-3-27 20:48:20 | 只看该作者
大家有没有看过奥运村那个直播塔的原来方案??
发表于 2010-3-28 00:55:23 | 只看该作者
非常宏伟壮观!
发表于 2010-3-28 10:19:52 | 只看该作者
那就练习练习吧
发表于 2010-3-30 10:39:39 | 只看该作者
{:3_62:}像一朵大花
发表于 2010-4-20 13:41:54 | 只看该作者
dingdingding!
发表于 2010-8-19 20:09:28 | 只看该作者
网站里的作品很强大~~
发表于 2010-8-19 21:15:46 | 只看该作者
hoho,就在emirates tower 附近, sheikh zayed road 边上,不错啊,全是高层,那么大的风效应,做成如此结构形式,怀疑其可行性,仅仅还是建筑方案吧,讨论完结构形式后,未必能按图作出来。尽管迪拜没有什么地震,不过风还是蛮大的。
发表于 2010-8-26 21:58:59 | 只看该作者
接触中,谢谢楼主分享。。。
发表于 2010-8-30 17:09:41 | 只看该作者
镂空的部分似乎使用了自重很轻的材料,完全实心的部分则是主承受了大部分外力吧。
发表于 2010-9-20 09:02:20 | 只看该作者
GOOD!谢谢分享!
发表于 2010-9-20 21:19:27 | 只看该作者
GOOD!谢谢分享
发表于 2010-9-20 23:41:22 | 只看该作者
网站挺好,只是我网速不行.一张张图片点开是个大工程
发表于 2010-9-22 14:37:23 | 只看该作者
学习一下~~~~~~
发表于 2010-9-24 20:20:53 | 只看该作者
路过~~ 谢楼主~~
发表于 2011-6-7 15:00:59 | 只看该作者
luguo1,能看
GMT+8, 2026-5-17 06:13 , Processed in 0.067082 second(s), 27 queries , Gzip On.
