查看: 21240|回复: 8
[工作记录] monkey 新手问题。。。线面交点怎么求??
发表于 2010-4-14 23:44:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个面与一个curve 求交点 是哪个命令?
试了半天CurveBrepIntersect总是说我类型不对啊啊啊。。。
发表于 2010-4-15 18:27:22 | 只看该作者
没有研究过,等待高人解答
发表于 2010-4-15 20:10:21 | 只看该作者
楼主可以试试CurveSurfaceIntersection命令
参与人数 1强度 +3 照度 +22 收起 理由
tony_tsang + 3 + 22
发表于 2010-4-15 20:42:39 | 只看该作者
曲线-物件交集
发表于 2010-5-19 23:52:28 | 只看该作者
也是初学,所以不懂
发表于 2010-5-25 23:38:03 | 只看该作者
同意3楼...
发表于 2010-5-27 15:19:02 | 只看该作者
我看了help可以直接用。
Sub CSX()
Const rhObjectCurve = 4
Const rhObjectSurface = 8
Dim strCurve, strSurface, arrCSX
strCurve = Rhino.GetObject("Select curve", rhObjectCurve)
If IsNull(strCurve) Or Rhino.IsCurve(strCurve) = False Then Exit Sub
strSurface = Rhino.GetObject("Select surface", rhObjectSurface)
If IsNull(strSurface) Or Rhino.IsSurface(strSurface) = False Then Exit Sub
arrCSX = Rhino.CurveSurfaceIntersection(strCurve, strSurface)
If Not IsArray(arrCSX) Then
Rhino.Print "Curve and surface do not intersect."
Exit Sub
For i = 0 To UBound(arrCSX)
If arrCSX(i,0) = 1 Then
Rhino.Print "Point"
Rhino.Print "Intersection point on curve: " & Rhino.Pt2Str(arrCSX(i,1))
Rhino.Print "Intersection point on surface: " & Rhino.Pt2Str(arrCSX(i,3))
Rhino.Print "Curve parameter: " & CStr(arrCSX(i,5))
Rhino.Print "Surface parameter: " & CStr(arrCSX(i,7)) & "," & CStr(arrCSX(i,8))
Else
Rhino.Print "Overlap"
Rhino.Print "Intersection start point on curve: " & Rhino.Pt2Str(arrCSX(i,1))
Rhino.Print "Intersection end point on curve: " & Rhino.Pt2Str(arrCSX(i,2))
Rhino.Print "Intersection start point on surface: " & Rhino.Pt2Str(arrCSX(i,3))
Rhino.Print "Intersection end point on surface: " & Rhino.Pt2Str(arrCSX(i,4))
Rhino.Print "Curve parameter range: " & CStr(arrCSX(i,5)) & " to " & CStr(arrCSX(i,6))
Rhino.Print "Surface parameter range: " & CStr(arrCSX(i,7)) & "," & CStr(arrCSX(i,8)) & " to " &  CStr(arrCSX(i,9)) & "," & CStr(arrCSX(i,10))
发表于 2010-5-28 23:45:32 | 只看该作者
如果要大量的做线面求交,且不在乎交点的精度,建议把曲面离散成mesh,然后抽出每个三角面片的顶点,再用几何算法计算交点。这种算法的速度比CurveSurfaceIntersection能提高差不多1~2个数量级。
p.s. 希望你的中学数学还没忘光
参与人数 1强度 +2 照度 +24 收起 理由
tony_tsang + 2 + 24 我很赞同
发表于 2013-2-22 08:07:51 | 只看该作者
做标记做标记做标记做标记做标记做标记做标记
GMT+8, 2026-7-1 15:30 , Processed in 0.200390 second(s), 24 queries , Gzip On.
