查看: 20016|回复: 2
[设计鉴赏] 先锋建筑的圣经 atlas of novel tectonics的作者reiser + umemoto代表作品2
发表于 2010-5-10 23:31:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
reiser + umemoto architects : 'aeon II', dubai
'aeon II' by reiser + umemoto architects
all images courtesy reiser + umemoto architects
new york architectural firm reiser + umemoto have designed 'aeon II' an office tower
building located in dubai, united arab emirates.
with 'aeon II', the dubai norm of slick curtain wall clad towers has been put aside in
favor of a responsive cladding system in tune with the arid desert environment. the folded
plan-form of this 45-story building combines the inherent efficiency of parallel floor slabs
with rich sculptural possibilities. there are many benefits to this new configuration. while
systematic and rational, each floor plate allows for unique office configurations, ranging
from boutique to mid-size. superlative views are created in the tips of the folds resulting
in more corner offices. moreover, the folded form creates an inherently stiff outer surface,
which frees the cores from the burden of lateral forces and radically reduces the roles of
cores in shear capacity.
for the building's skin a new concept is being proposed. rather than the typical curtain wall
solution, they proposed an economical floor to ceiling window-wall assembly which also
allows for the creation of the buildings folded forms. the glazing steps rather than wraps
and will be entirely standardized. the building’s reticulated skin is made of perforated
aluminum panels. these will have a beneficial effect both aesthetically and environmentally,
shading the building from glare and heat, yet allowing for directed views from within the
offices. the rich variation and quality of the outer fabric is created by following the folded
building form. thus while every built element is standard, the openings between are unusual
and continuously vary.
http://www.reiser-umemoto.com
read designboom's article on the future in dubai
'aeon II' - cladding detail
'aeon II'
'aeon II'
'aeon II' - exterior detail
'aeon II' - interior detail
出自http://www.designboom.com/weblog/cat/9/view/5454/reiser-umemoto-architects-aeon-ii-dubai.html
参与人数 1照度 +10 收起 理由
skywoolf + 10
发表于 2010-5-11 23:59:43 | 只看该作者
非常想知道那座模型的制作过程,一定是费尽心力(人或机器的)吧。
学习学习……
发表于 2010-8-28 21:20:45 | 只看该作者
像是蛇皮!
GMT+8, 2026-7-2 04:15 , Processed in 0.579757 second(s), 25 queries , Gzip On.
