查看: 14249|回复: 2
[网络资源] Autodesk TSplines 2013
发表于 2013-3-2 17:51:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
So, to put an end to those that are searching for cracks to TSplines (or any Autodesk Software). I've decided to write this short tutorial on how to get everything working as quickly as possible without the use of cracks.
Step 1
Register and activate a student account at Autodesk:
Link(s):
https://students.autodesk.com
Step 2
At the top of the home page, click on Free Software and then navigate towards the bottom of the page to where Tsplines is. Grab a license key by selecting your Version, Language, and then OS type. Now. either continue with the download of the 32bit version or go back to click the link to the 64bit version or just go here:
Link(s):
http://www.tsplines.com/latestversion
http://www.tsplines.com/resource ... 8555ForRhino_32.msi
http://www.tsplines.com/resource ... 8555ForRhino_64.msi
Step 3
After you install the software, make sure you are connected to the internet and then either type in tsActivateLicense into the command line followed by pasting your Internet Activation Key (You should have received an email from autodesk containing your license after completing the previous step) or from the file menu click T-Splines>Utilities>Activate License.
See here for manually activating your license should your run into any trouble:
Link(s):
http://www.tsplines.com/license.html
License Policy:
Quote:
Autodesk T-Splines Plug-in for Rhino licenses can be installed on one desktop and one laptop/home computer per user. Licenses are hard-coded to your machine. (Which means that you cannot share your license with others)
In the event that you upgrade your computer, you can deactivate the license on your old computer by clicking on the T-Splines menu in Rhino, then Help, then About T-Splines. Then, click on the Deactivate License button, and you will be able to use your license on a new computer. You can also email us and we can deactivate your license for you.
Also, you should read the manual as well before doing anything:
Link(s):
http://www.tsplines.com/support/usermanual.html
Let me know if you have any problems and Have fun!
Setup:
1. Open Rhino x64
2.Go : menu->T-Splines->Utilities-> Activate Licence
3. Copy paste MY serialTSplines 32
TSplines 64
发表于 2013-3-2 18:09:54 | 只看该作者
上午还在找破解版来着,学生版有什么限制么
发表于 2013-3-2 19:52:02 | 只看该作者
GMT+8, 2026-7-2 03:23 , Processed in 0.533935 second(s), 23 queries , Gzip On.
