查看: 9763|回复: 12
[网络资源] RVB ATTRACTOR SERIES 02: GUMOWSKI-MIRA
发表于 2010-6-12 14:34:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Gumowski-Mira attractors were developed at the CERN research centre in 1980 by I. Gumowski and C. Mira while aiming to calculate the trajectories of sub-atomic particles. They create organic patterns resembling natural/marine forms.
 楼主| 发表于 2010-6-12 14:35:48 | 只看该作者
Option Explicit
‘Script written by Elif Erdine
Call GumowskiMira()
Sub GumowskiMira()
Dim i
Dim x()
Dim y()
Dim pt()
Dim maxpoints
maxpoints = 5000
Dim
B
B = 1
ReDim Preserve x(maxpoints)
ReDim Preserve y(maxpoints)
x(i) = 0
y(i) = 5
i=0
Do While (i < maxpoints)
x(i+1) = B*y(i) + GM(x(i))
y(i+1) = GM(x(i+1)) – x(i)
ReDim Preserve pt(i)
pt(i) = Array(x(i), y(i), 0)
If IsArray(pt(i)) Then
Call Rhino.AddPoint(pt(i))
Dim plane
plane = Rhino.PlaneFromNormal(pt(i), Array(0,0,1))
Call Rhino.AddCircle(plane, 0.2)
i = i+1
Loop
If IsArray(pt) Then
Dim ptcloud
ptcloud = Rhino.AddPointCloud(pt)
Dim ptdel
ptdel =
Rhino.GetObjects(”select points to delete”, 1, , , True)
Call Rhino.DeleteObjects(ptdel)
Function GM (ByVal x)
Dim A
A= 0.305
GM = A*x + 2*(1-A)*x^2 / (1+x^2)
End Function
[size=0.9em]Posted:
April 16th, 2009 under
Parametric Design.
Comments:
1
.RVB ATTRACTOR SERIES 01: ROSSLER ATTRACTORRossler attractor behaves similarly to Lorenz attractor. It’s formed by 3 non-linear ordinary differential equations. (
http://en.wikipedia.org/wiki/Rossler_map
 楼主| 发表于 2010-6-12 14:36:41 | 只看该作者
Call Rossler()
Sub Rossler()
Dim x, y, z
Dim maxpoints
maxpoints = 8000
Dim h
h = 0.025
Dim p(2)
Dim ptnew()
Dim i
Do While (i<maxpoints)
p(0) = p(0) + h* dx(p(0), p(1), p(2))
p(1) = p(1) + h* dy(p(0), p(1), p(2))
p(2) = p(2) + h* dz(p(0), p(1), p(2))
Rhino.AddPoint(p)
ReDim Preserve ptnew(i)
ptnew(i) = p
i=i+1
Loop
Call Rhino.AddCurve(ptnew, 3)
Function dx(ByVal x, ByVal y, ByVal z)
dx = -y-z
End Function
Function dy(ByVal x, ByVal y, ByVal z)
dy = x + 0.4*y
End Function
Function dz(ByVal x, ByVal y, ByVal z)
dz = 0.31 + z*(x-5.3)
End Function
[size=0.9em]Posted:
Parametric Design.
Comments:
none
.RVB CURLICUE FRACTALI’ve recently started using Rhino Scripting as a design tool in my research. I will be documenting here my learning process through the .rvb scripts.
This study shows the Curlicue Fractal, which generates quite intricate patterns. (http://mathworld.wolfram.com/CurlicueFractal.html)
 楼主| 发表于 2010-6-12 14:38:00 | 只看该作者
Call Curlicue()
Sub Curlicue()
            Dim f
            Dim i
            Dim j
            Dim pi
            pi = Rhino.Pi
            Dim sqtwo
            sqtwo = 1.4142135623730950488016887
            Dim eulers
            eulers = 0.577215664901532860606512
            Dim golden
            golden = 1.618033988749894848204586
            Dim lntwo
            lntwo = 0.69314718055994530941
            Dim e
            e= 2.71828182845904523536028747
            Dim p(2)
            Dim ptCur()
            For j=0 To 50000*pi Step sqtwo*pi*2
                        f = f + j
                        p(0)= p(0) + Cos(f)
                        p(1)= p(1)+ Sin(f)
                        p(2)=p(2) + Cos(f)*Sin(f)
                        ‘Rhino.AddPoint(p)
                        ReDim Preserve ptCur(i)
                        ptCur(i) = p
                        i=i+1
            Call Rhino.addcurve(ptCur, 3)
Posted: April 16th, 2009 under Parametric Design.
Comments: none
skywoolf + 3 + 30 感谢分享
发表于 2010-6-12 15:24:56 | 只看该作者
强大!!!!!!!!
发表于 2010-6-14 14:53:17 | 只看该作者
好    厉害的rvb.
发表于 2010-6-14 23:57:26 | 只看该作者
来个打包的,xiexie
发表于 2010-6-17 16:45:00 | 只看该作者
厉害。。。。
发表于 2011-4-28 17:19:30 | 只看该作者
very good!!!
发表于 2011-5-8 17:11:53 | 只看该作者
赞 , 厉害 !
发表于 2011-5-28 00:20:01 | 只看该作者
貌似好深奥啊
发表于 2011-7-1 16:24:44 | 只看该作者
学的好慢啊
发表于 2011-7-15 09:01:52 | 只看该作者
赞一个 谢谢楼主
GMT+8, 2026-7-4 07:46 , Processed in 0.594020 second(s), 27 queries , Gzip On.
