查看: 20114|回复: 9
[设计鉴赏] 哥伦比亚,水泥厂的发电机房/Felipe Gonzalez-Pacheco
发表于 2010-7-15 07:55:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Argos, Building for an Electrical Generator at a Cement Factory / Felipe Gonzalez-Pacheco
13 Jul 2010
By Nico Saieh — Filed under: Industrial Architecture , Selected , Colombia, Concrete, Felipe Gonzalez-Pacheco
© Andrés Valbuena
Architects: Felipe Gonzalez-Pacheco & Juan Ignacio Muñoz (MGP Arquitectura y Urbanismo)
Collaborators: Alvaro Bohorquez, Camilo Correa, M. Juliana Sorzano
Client: Cementos Argos
Contractor:  Concreto S.A. – Cementos Argos
Constructed Area: 575 sqm
Project Year: 2008
Photographs: Andrés Valbuena
first floor plan
section 01
In July 2006, the project is the winner of an architectural contest, for the resolution of a “skin” for a technical building containing an self generation electrical plant for cement factory. The Factory wanted to generate also a corporative image with the building. Their purpose became a mutual opportunity to generate an experimentation laboratory of technical possibilities with the material they produce, with very low density concretes. In a parallel way with the technical solution we found a high symbolic value in cultural textures found in the 3 sites the project was built, which had manual work implied, making an industrial building a reference for the local people of each site.
© Andrés Valbuena
© Andrés Valbuena
As a result we designed 2 great format prefabricated pieces placed in a way to simulate the textures made by the locals in fibers to fabricate artisanal objects.
f56a46a5dfe04e5c8305b46e85991a06
© Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena © Andrés Valbuena first floor plan roof plan elevation 01 section 01 detail 01 detail 02 detail 03 render 01 render 02
from
http://www.archdaily.com/68511/argos-building-for-an-electrical-generator-at-a-cement-factory-felipe-gonzalez-pacheco/
 楼主| 发表于 2010-7-15 07:58:14 | 只看该作者
该项目2006年7月竞赛获胜,它是水泥厂的发电机房,采用“皮肤”技术。该建筑也要去代表工厂的形象。厂方希望它成为工厂低密度水泥的实验品。它不仅仅是技术解决方案,也具有当地文化上的象征意义,使得这个工业建筑能代表当地的人们。
引自 http://www.archgo.com
发表于 2010-7-15 12:58:04 | 只看该作者
低密度水泥的重量看来相当的“轻”
发表于 2010-7-15 20:49:38 | 只看该作者
确实不错,别人的工厂建筑都如此重视,我很感动
发表于 2010-7-15 21:51:37 | 只看该作者
不晓得国内水泥厂会花钱设计发电机房啵
发表于 2010-7-15 22:22:59 | 只看该作者
575平方米的发电机房,看得人内牛满面……
国内的甲方要是看到这个,一定会嘲笑建筑师脑子进水了……
这就是差距啊……
发表于 2010-7-16 00:41:13 | 只看该作者
国内估计就一水泥盒子....
发表于 2010-7-16 21:54:31 | 只看该作者
upup
up
up
up
发表于 2010-7-17 13:23:01 | 只看该作者
很好    可惜它只是个发电机房   表皮不符合建筑的身份
发表于 2010-7-25 22:37:56 | 只看该作者
很不错的建筑,非常喜欢,谢谢推荐
GMT+8, 2026-7-4 15:39 , Processed in 0.097057 second(s), 23 queries , Gzip On.
