查看: 7223|回复: 6
[设计鉴赏] Periscope / Matter Design (附构件加工视频)
发表于 2010-7-16 09:02:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Periscope / Matter Design 15 Jul 2010 By Karen Cilento — Filed under: Awarded Competitions , Building Technology and Materials , News , Atlanta, Georgia, Matter Design, Periscope © Matter Design For the Young Architects Forum Atlanta’s 10UP! National Architectue Competition, participants were challenged to create a temporary installation for Atlanta. The winning 45 ft tower, Periscope, designed by Brandon Clifford and Wes Mcgee of Matter Design Studio, is an “inhabitable installation with iconic implications to advocate bold architecture for the Atlanta community and young designers across the globe.” The designers felt the tower would create a strong marker for the city, “Through vertical expansion via the omission of a vertical restriction, this tower will engage a broader audience, inviting them to the event similar to search lights in the night sky.” More about the tower, including lots of images and a video, after the break. © Matter Design Assembled in only 6 hours with the aid of Tier son Boutte of Boutte Tree, the slanting tower is coated with expanded polystyrene which were formed by computerized cutting via robotic hot wire. Inside this layer, parts of “Porex” have been mounted on a wooden inner frame that are assembled and stabilized by the steel cable turnbuckles attached to the base, a wooden box concealing counterweight blocks. © Matter Design The tower’s exterior expression can be a little difficult to read for what appears as fabric stretched across compressive rods is quite the opposite – the foam is compressive and the rods are actually performing as tensile cables. “This rhetorical inversion invites spectators in for closer inspection to find the tower is not constructed of thin surfaces at all, but rather carved from solid blocks of EPS foam,” added the architects. © Matter Design The foam, by its nature, is inherently volumetric and light weight. Yet, the foam is also delicate and requires a great deal of precision to handle larger assemblies. “This proposal takes advantage of larger than life size build ing blocks to achieve a quickly constructed, and relatively large installation.” 视频地址: http://vimeo.com/12536845 Often times, in digitally fabricated projects, too much waste can be generated; however, the designers were aware of this and sought a way to eliminate the excess waste. “Beyond the efficiency of unit nesting, the methods of fabrication (robotic hotwire) produces no kerf waste and the minimal waste produced in starting and stopping a stock block produce 100% recyclable material. The research and development behind the means and methods of fabrication speak to our approach to design – reciprocity between drawing and making,” added the architects. year: 2010 design team: bran don clif ford, wes mcgee, dave pigram struc tural: matthew john son build team: bran don clif ford, wes mcgee, maciej kaczyn ski, johanna lob dell, deniz mcgee, kris wal ters rig ging: tier son boutte fab ri ca tion: uni ver sity of michi gan taub man col lege of archi tec ture and urban plan ning client: mod ern atlanta 10up competition Source: blob.bellostes 转自:http://www.archdaily.com/69081/periscope-matter-design/
参与人数 1强度 +3 照度 +35 收起 理由
董羽天 + 3 + 35 辛苦了
 楼主| 发表于 2010-7-16 09:10:11 | 只看该作者
犀利的切割技术~{:3_56:}
发表于 2010-7-16 10:59:21 | 只看该作者
高薪的施工技术!赞!
发表于 2010-7-16 12:05:38 | 只看该作者
施工图是个大问题
发表于 2010-7-16 21:18:52 | 只看该作者
O(∩_∩)O哈哈哈~犀利啊
发表于 2010-7-17 10:34:41 | 只看该作者
很是犀利啊..
发表于 2010-7-18 22:20:47 | 只看该作者
uppup up up up
GMT+8, 2026-7-5 02:09 , Processed in 0.075212 second(s), 24 queries , Gzip On.
