查看: 22247|回复: 11
[工作记录] 求助 SketchUp class 方法 。。。?
发表于 2010-8-11 18:56:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这就是Sketchup类的所有方法
"display", "to_a", "vcb_value=", "register_extension", "const_defined?", "find_support_file", "autoload?", "to_s", "nil?", "register_importer", "included_modules", "respond_to?", "find_support_files", "const_missing", "inspect", "equal?", "undo", "instance_method", "template_dir", "class_variables", "methods", "include?", "eql?", "method_defined?", "name", "create_texture_writer", "hash", "template", "singleton_methods", "version", "template=", "public_method_defined?", "ancestors", "add_observer", "id", "save_thumbnail", "protected_methods", "version_number", "private_method_defined?", "remove_observer", "__id__", "format_length", "private_methods", "app_name", "protected_method_defined?", "is_online", "object_id", "public_class_method", "parse_length", "public_methods", "os_language", "<=>", "==", "<", "type", "===", "private_class_method", ">", ">=", "format_area", "<=", "instance_variables", "active_model", "=~", "class", "module_eval", "format_angle", "get_datfile_info", "instance_variable_get", "instance_methods", "class_eval", "clone", "format_degrees", "instance_variable_set", "__send__", "public_instance_methods", "dup", "send_action", "is_valid_filename?", "wikii_push_pull", "open_file", "protected_instance_methods", "taint", "display_name_from_action", "send", "file_new", "private_instance_methods", "get_shortcuts", "instance_of?", "instance_eval", "set_status_text", "tainted?", "load", "constants", "untaint", "write_default", "kind_of?", "require", "const_get", "freeze", "status_text=", "read_default", "is_a?", "autoload", "const_set", "vcb_label=", "extend", "get_locale", "method", "frozen?"
 楼主| 发表于 2010-8-11 18:58:07 | 只看该作者
但是在api里面的方法只有这些
Sketchup Module
The Sketchup module contains number of important utility methods for use in your Ruby scripts.
Parent:N/A
Methods: active_model, add_observer, app_name, create_texture_writer, display_name_from_action, file_new, find_support_file, find_support_files, format_angle, format_area, format_degrees, format_length, get_datfile_info, get_locale, get_shortcuts, is_online, is_valid_filename?, load, open_file, os_language,  parse_length, read_default, register_extension, register_importer, remove_observer, require, save_thumbnail, send_action, set_status_text=, set_status_text, template, template=, template_dir, undo, vcb_label=, vcb_value=, version, version_number, write_default
不知剩下的方法的帮助如何找
发表于 2010-8-12 11:54:29 | 只看该作者
不知道楼主发的什么东西,有待学习中~~~
发表于 2010-8-12 23:55:18 | 只看该作者
什么情况?!SU?代码?{:3_69:}
发表于 2010-8-13 12:27:14 | 只看该作者
 楼主| 发表于 2010-8-14 23:59:17 | 只看该作者
6# 3828669
好像不是哦 我是在控制台里面输入sketchup.method看到的方法
发表于 2011-1-27 20:28:11 | 只看该作者
高出不胜寒。
发表于 2011-1-27 20:29:11 | 只看该作者
你知道sketchupbar的powermedia版主吗?你可以问他。
发表于 2011-2-27 17:43:18 | 只看该作者
sktechup还能编程吗?
发表于 2011-3-3 16:30:43 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-5-11 00:39:43 | 只看该作者
看不懂。。。。。{:3_62:}
发表于 2012-1-30 11:12:01 | 只看该作者
好高级的赶脚。。
GMT+8, 2026-7-2 04:41 , Processed in 0.627278 second(s), 23 queries , Gzip On.
