查看: 54911|回复: 60
Rhino中的天正—VisualARQ插件
发表于 2009-9-26 17:41:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 tomee 于 2009-9-29 02:06 编辑 What is VisualARQ? VisualARQ is aimed at Rhino Users in architectural markets (architects, interior designers developers, etc) who want to streamline their workflow and improve their design process efficiency within one production environment, avoiding the associated loss in time and information that transferring to other programmes and formats entails. This unique and fully integrated plug-in for Rhino offers a powerful feature based editor that allows you to easily create and edit smart/custom architectural objects, and provides as well a set of architectural tools that make the design and documentation process faster and easier to handle. Unlike other products in the market, VisualARQ integrates intuitively in the Rhino design workflow with the shortest learning curve and at a very affordable price. 目前尚处于beta版测试阶段,按要求下载会提供对应下载机器的注册码,还是挺有用的,值得一试 链接:http://www.visualarq.com/ 09.09.29收到的邮件:看来是最后一版测试版了,以后准备要收费了: I’m writing you to let you know that VisualARQ’s first commercial release is just around the cornerVisualARQ RC2, the last “Beta version” we will release to close this first development stage, is ready to download from www.visualarq.com. Give it a try and let us know what you think about it! NOTE: Since Rhino 5.0 is still at a development stage and could cause problems, VisualARQ does not support this version. As soon as Rhino 5.0 is production ready, we will release a compatible build for it. _________________________________ What’s New in RC2:
  • Files that were edited in Rhino without VisualARQ being loaded can now be opened.
  • Standard wall, column, door and window styles have been added to the VisualARQ Templates (only available in English, for the moment).
  • Command to set the current floor within a view window has been added: vaSetCurrentFloor
  • The “Height by Style” option has been added for columns
  • The Plan and Model display for sliding doors and windows has been added.
  • The Model display for the window leaves’ glass has been added.
  • VisualARQ’s “Welcome window” has been added.
  • The command “About VisualARQ” (vaAbout) showing the installed version’s information has been added.
  • Imperial distances input has been improved.
  • Support for Print Color and Dimension Styles has been added.
  • Dynamic dimensions appear while drawing walls (vaWall).
  • All known bugs have been fixed.
Expire date is now 31th January 2010.
参与人数 3强度 +4 照度 +90 收起 理由
denghua + 1 + 10
skywoolf + 1 + 40 欢迎分享!
f(x) + 2 + 40 主动分享资源,给予加分!
发表于 2009-9-26 18:48:27 | 只看该作者
在wiki里见过这个东西,用法类似于CAD,不过没有下载来用,不知道LZ是否用过,可否稍微深入的介绍一下。会继续给你加分的。足够深入就加精。
 楼主| 发表于 2009-9-27 19:00:43 | 只看该作者
我是用过,但不常用,比较容易使用的插件,最近时间过于匆忙,看看国庆假期补充一下~
发表于 2009-9-27 23:36:30 | 只看该作者
嗯,深入介绍一下,先期待一下。
发表于 2009-9-28 17:10:59 | 只看该作者
今天下午在家就装SR6玩了,郁闷死了,不过总算是安装完成了,试了一下VisualARQ这个插件,不错。可以省掉从CAD到SU的过程了,直接CAD操作,然后直接成模型,我简单的尝试了一下,当然了,功能肯定不如天正,如果不是非常要求图的质量,如果不是异形建筑,这个小插件可算是相当的省事的了。平立剖一步到位。看看小效果:
参与人数 1照度 +30 收起 理由
skywoolf + 30 下手很快啊~
发表于 2009-9-28 17:13:30 | 只看该作者
电脑里渲染器不好使,就不渲了。
 楼主| 发表于 2009-9-29 00:37:21 | 只看该作者
本帖最后由 tomee 于 2009-9-29 02:25 编辑 就是这么用,如果有很多层,定了标高后可以分层显示,遗憾的是窗门虽然可以自定义,但局限太大,如果是飘窗基本上也做不出来,形式太少,异形建筑也是可以使用的,有墙体捕捉功能。 *今早收到邮件,新版rc2窗的种类增加了,不少内容作了相应调整,没办法,快要收钱了
 楼主| 发表于 2009-9-29 02:28:00 | 只看该作者
本帖最后由 tomee 于 2009-9-29 02:33 编辑 还有,用Rhino来画cad也是可行的,官方自带文件,加载后快捷键和autocad完全一致
发表于 2009-9-29 07:05:42 | 只看该作者
今天发布的最后一版BETA么,我是昨天下载的
发表于 2009-9-29 07:07:08 | 只看该作者
如果这个东西像网游一样多好,BETA之后再来个公测!就完美了。
 楼主| 发表于 2009-9-29 18:14:50 | 只看该作者
这次的就是beta版后的公测啊~哈哈
发表于 2009-9-29 19:22:41 | 只看该作者
BETA版只要有注册码就可以随便用吧
发表于 2009-11-11 22:49:42 | 只看该作者
我考,那个软件卖的好贵!
发表于 2009-11-13 20:10:53 | 只看该作者
蛮实用的啊~~~
发表于 2009-11-13 20:11:23 | 只看该作者
蛮实用的啊~~~
发表于 2009-11-16 23:56:44 | 只看该作者
很好很强大哦 {:3_50:}
发表于 2009-11-17 10:42:36 | 只看该作者
我斜着的墙他门窗照样给我正这的开,洞和们对不上 我都笑抽了
发表于 2009-11-26 08:03:14 | 只看该作者
应该是你rhino里的单位设置问题吧
发表于 2009-11-26 09:24:43 | 只看该作者
都英文的 看不懂 哟hohohoho
发表于 2009-12-17 21:12:13 | 只看该作者
要求SR5 我还停留在SR4阶段。。。。。
GMT+8, 2026-7-3 12:32 , Processed in 0.083230 second(s), 26 queries , Gzip On.
