查看: 7908|回复: 14
[工作记录] Revit几何创建代码
发表于 2010-9-24 17:52:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
官网资源整理
调用库:
Imports Autodesk.Revit
Imports Autodesk.Revit.DB
成员变量:
   Private m_revit As Autodesk.Revit.ApplicationServices.Application
    Private m_thisDoc As ThisDocument
    Private m_familyDocument As Autodesk.Revit.DB.Document
    Private m_creationFamily As Autodesk.Revit.Creation.FamilyItemFactory = Nothing
    Private m_isCreateFamilyDoc As Boolean = False
    Private m_errCount As Integer = 0
    Private m_errorInfo As String = ""
参与人数 3强度 +16 照度 +70 收起 理由
musofan + 3 + 30
skywoolf + 3 + 30
wuliang + 10 + 10 good!
 楼主| 发表于 2010-9-24 17:53:36 | 只看该作者
挤出物体:
  Private Sub CreateExtrusion()
        Try
            '#Region "Create rectangle profile"
            Dim curveArrArray As CurveArrArray = m_revit.Create.NewCurveArrArray()
            Dim curveArray1 As CurveArray = m_revit.Create.NewCurveArray()
            Dim curveArray2 As CurveArray = m_revit.Create.NewCurveArray()
            Dim curveArray3 As CurveArray = m_revit.Create.NewCurveArray()
            Dim normal As Autodesk.Revit.DB.XYZ = Autodesk.Revit.DB.XYZ.BasisZ
            Dim sketchPlane As Autodesk.Revit.DB.SketchPlane = CreateSketchPlane(normal, Autodesk.Revit.DB.XYZ.Zero)
            ' create one rectangular extrusion
            Dim p0 As Autodesk.Revit.DB.XYZ = Autodesk.Revit.DB.XYZ.Zero
            Dim p1 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(10, 0, 0)
            Dim p2 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(10, 10, 0)
            Dim p3 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 10, 0)
            Dim line1 As Line = m_revit.Create.NewLineBound(p0, p1)
            Dim line2 As Line = m_revit.Create.NewLineBound(p1, p2)
            Dim line3 As Line = m_revit.Create.NewLineBound(p2, p3)
            Dim line4 As Line = m_revit.Create.NewLineBound(p3, p0)
            curveArray1.Append(line1)
            curveArray1.Append(line2)
            curveArray1.Append(line3)
            curveArray1.Append(line4)
            curveArrArray.Append(curveArray1)
            '#End Region
            ' here create rectangular extrusion
            Dim rectExtrusion As Extrusion = m_creationFamily.NewExtrusion(True, curveArrArray, sketchPlane, 10)
            ' move to proper place
            Dim transPoint1 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(-16, 0, 0)
            m_familyDocument.Move(rectExtrusion, transPoint1)
        Catch e As Exception
            m_errCount += 1
            m_errorInfo += "Unexpected exceptions occur in CreateExtrusion: " & e.ToString() & vbCr & vbLf
        End Try
 楼主| 发表于 2010-9-24 17:54:36 | 只看该作者
Blend 物体
Private Sub CreateBlend()
        Try
            '#Region "Create top and base profiles"
            Dim topProfile As CurveArray = m_revit.Create.NewCurveArray()
            Dim baseProfile As CurveArray = m_revit.Create.NewCurveArray()
            ' create one blend
            Dim p00 As Autodesk.Revit.DB.XYZ = Autodesk.Revit.DB.XYZ.Zero
            Dim p01 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(10, 0, 0)
            Dim p02 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(10, 10, 0)
            Dim p03 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 10, 0)
            Dim line01 As Line = m_revit.Create.NewLineBound(p00, p01)
            Dim line02 As Line = m_revit.Create.NewLineBound(p01, p02)
            Dim line03 As Line = m_revit.Create.NewLineBound(p02, p03)
            Dim line04 As Line = m_revit.Create.NewLineBound(p03, p00)
            baseProfile.Append(line01)
            baseProfile.Append(line02)
            baseProfile.Append(line03)
            baseProfile.Append(line04)
            Dim p10 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(5, 2, 10)
            Dim p11 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(8, 5, 10)
            Dim p12 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(5, 8, 10)
            Dim p13 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(2, 5, 10)
            Dim line11 As Line = m_revit.Create.NewLineBound(p10, p11)
            Dim line12 As Line = m_revit.Create.NewLineBound(p11, p12)
            Dim line13 As Line = m_revit.Create.NewLineBound(p12, p13)
            Dim line14 As Line = m_revit.Create.NewLineBound(p13, p10)
            topProfile.Append(line11)
            topProfile.Append(line12)
            topProfile.Append(line13)
            topProfile.Append(line14)
            '#End Region
            ' here create rectangular blend
            Dim blend As Blend = m_creationFamily.NewBlend(True, topProfile, baseProfile, sketchPlane)
            Dim transPoint1 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 11, 0)
            m_familyDocument.Move(blend, transPoint1)
            m_errCount += 1
            m_errorInfo += "Unexpected exceptions occur in CreateBlend: " & e.ToString() & vbCr & vbLf
        End Try
 楼主| 发表于 2010-9-24 17:55:11 | 只看该作者
Revolut物体
Private Sub CreateRevolution()
        Try
            '#Region "Create rectangular profile"
            Dim curveArray As CurveArray = m_revit.Create.NewCurveArray()
            ' create one rectangular profile revolution
            Dim pp As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(1, -1, 0)
            Dim axis1 As Line = m_revit.Create.NewLineBound(Autodesk.Revit.DB.XYZ.Zero, pp)
            curveArray.Append(line1)
            curveArray.Append(line2)
            curveArray.Append(line3)
            curveArray.Append(line4)
            curveArrArray.Append(curveArray)
            '#End Region
            ' here create rectangular revolution
            Dim revolution1 As Revolution = m_creationFamily.NewRevolution(True, curveArrArray, sketchPlane, axis1, -Math.PI, 0)
            Dim transPoint1 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 32, 0)
            m_familyDocument.Move(revolution1, transPoint1)
            m_errCount += 1
            m_errorInfo += "Unexpected exceptions occur in CreateRevolution: " & e.ToString() & vbCr & vbLf
        End Try
 楼主| 发表于 2010-9-24 17:55:49 | 只看该作者
放样(单轴)
Private Sub CreateSweep()
        Try
            '#Region "Create rectangular profile and path curve"
            Dim arrarr As CurveArrArray = m_revit.Create.NewCurveArrArray()
            Dim arr As CurveArray = m_revit.Create.NewCurveArray()
            Dim pnt1 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 0, 0)
            Dim pnt2 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(2, 0, 0)
            Dim pnt3 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(1, 1, 0)
            arr.Append(m_revit.Create.NewArc(pnt2, 1.0R, 0.0R, 180.0R, Autodesk.Revit.DB.XYZ.BasisX, Autodesk.Revit.DB.XYZ.BasisY))
            arr.Append(m_revit.Create.NewArc(pnt1, pnt3, pnt2))
            arrarr.Append(arr)
            Dim profile As SweepProfile = m_revit.Create.NewCurveLoopsProfile(arrarr)
            Dim pnt4 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(10, 0, 0)
            Dim pnt5 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 10, 0)
            Dim curve As Curve = m_revit.Create.NewLineBound(pnt4, pnt5)
            Dim curves As CurveArray = m_revit.Create.NewCurveArray()
            curves.Append(curve)
            '#End Region
            ' here create rectangular sweep
            Dim sweep1 As Sweep = m_creationFamily.NewSweep(True, curves, sketchPlane, profile, 0, ProfilePlaneLocation.Start)
            Dim transPoint1 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(11, 0, 0)
            m_familyDocument.Move(sweep1, transPoint1)
            m_errCount += 1
            m_errorInfo += "Unexpected exceptions occur in CreateSweep: " & e.ToString() & vbCr & vbLf
        End Try
 楼主| 发表于 2010-9-24 17:56:40 | 只看该作者
放样
Private Sub CreateSweptBlend()
        Try
            '#Region "Create top and bottom profiles and path curve"
            Dim pnt2 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(1, 0, 0)
            Dim pnt4 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 1, 0)
            Dim pnt5 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 0, 1)
            Dim arrarr1 As CurveArrArray = m_revit.Create.NewCurveArrArray()
            Dim arr1 As CurveArray = m_revit.Create.NewCurveArray()
            arr1.Append(m_revit.Create.NewLineBound(pnt1, pnt2))
            arr1.Append(m_revit.Create.NewLineBound(pnt2, pnt3))
            arr1.Append(m_revit.Create.NewLineBound(pnt3, pnt4))
            arr1.Append(m_revit.Create.NewLineBound(pnt4, pnt1))
            arrarr1.Append(arr1)
            Dim pnt6 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0.5, 0, 0)
            Dim pnt7 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(1, 0.5, 0)
            Dim pnt8 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0.5, 1, 0)
            Dim pnt9 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 0.5, 0)
            Dim arrarr2 As CurveArrArray = m_revit.Create.NewCurveArrArray()
            Dim arr2 As CurveArray = m_revit.Create.NewCurveArray()
            arr2.Append(m_revit.Create.NewLineBound(pnt6, pnt7))
            arr2.Append(m_revit.Create.NewLineBound(pnt7, pnt8))
            arr2.Append(m_revit.Create.NewLineBound(pnt8, pnt9))
            arr2.Append(m_revit.Create.NewLineBound(pnt9, pnt6))
            arrarr2.Append(arr2)
            Dim bottomProfile As SweepProfile = m_revit.Create.NewCurveLoopsProfile(arrarr1)
            Dim topProfile As SweepProfile = m_revit.Create.NewCurveLoopsProfile(arrarr2)
            Dim pnt10 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(5, 0, 0)
            Dim pnt11 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(0, 20, 0)
            Dim curve As Curve = m_revit.Create.NewLineBound(pnt10, pnt11)
            '#End Region
            ' here create rectangular sweep blend
            Dim newSweptBlend1 As SweptBlend = m_creationFamily.NewSweptBlend(True, curve, sketchPlane, bottomProfile, topProfile)
            Dim transPoint1 As Autodesk.Revit.DB.XYZ = m_revit.Create.NewXYZ(11, 32, 0)
            m_familyDocument.Move(newSweptBlend1, transPoint1)
            m_errCount += 1
            m_errorInfo += "Unexpected exceptions occur in CreateSweptBlend: " & e.ToString() & vbCr & vbLf
        End Try
 楼主| 发表于 2010-9-24 17:57:29 | 只看该作者
其它函数两个
Private Function GetElement(Of T As Autodesk.Revit.DB.Element)(ByVal eid As Integer) As T
        Dim elementId As New Autodesk.Revit.DB.ElementId(eid)
        Return TryCast(m_familyDocument.Element(elementId), T)
    End Function
    Friend Function CreateSketchPlane(ByVal normal As Autodesk.Revit.DB.XYZ, ByVal origin As Autodesk.Revit.DB.XYZ) As Autodesk.Revit.DB.SketchPlane
        ' First create a Geometry.Plane which need in NewSketchPlane() method
        Dim geometryPlane As Autodesk.Revit.DB.Plane = m_revit.Create.NewPlane(normal, origin)
        If geometryPlane Is Nothing Then
            ' assert the creation is successful
            Throw New Exception("Create the geometry plane failed.")
        ' Then create a sketch plane using the Geometry.Plane
        Dim plane As Autodesk.Revit.DB.SketchPlane = m_creationFamily.NewSketchPlane(geometryPlane)
        ' throw exception if creation failed
        If plane Is Nothing Then
            Throw New Exception("Create the sketch plane failed.")
        Return plane
    End Function
发表于 2010-9-25 20:55:16 | 只看该作者
啥意思,没看懂,请详细解释下。
发表于 2010-9-26 02:30:38 | 只看该作者
不错 学习了
发表于 2010-9-26 09:10:03 | 只看该作者
没看懂~~~~~~
发表于 2010-9-26 10:48:02 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-12-10 14:18:03 | 只看该作者
支持一个~~~~~~~~~~~~
发表于 2010-12-10 21:34:06 | 只看该作者
不熟悉revitapi的看不懂。。。
发表于 2011-12-31 08:09:32 | 只看该作者
围观学习中。。。
发表于 2012-3-1 08:46:58 | 只看该作者
【效率小额贷款】成立于2002年,拥有雄厚的资金,办理简单,低利息,免担保、操作明细。代办信用卡联系79711981 联系号码:13522264292
GMT+8, 2026-7-2 07:42 , Processed in 0.744600 second(s), 24 queries , Gzip On.
