查看: 16832|回复: 1
[话题讨论] 调用RHINO.COMMAND如果在执行中选择物体如何操作
发表于 2010-11-7 22:43:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
例如call rhino.command("_split")其后要选择一个物体使用什么代码?
 楼主| 发表于 2010-11-8 12:06:18 | 只看该作者
Function DoBrepSplit(brep, cutter)
   ' Declare local variables
   Dim saved, cmd
   ' Set default return value
   DoBrepSplit = Null
   ' For speed, turn of screen redrawing
   Rhino.EnableRedraw False
   ' Save any selected objects
   saved = Rhino.SelectedObjects
   ' Unselect all objects
   Rhino.UnSelectAllObjects
   ' Select the brep
   Rhino.SelectObject brep
   ' Script the split command
   cmd = "_Split _SelID " & cutter & " _Enter"
   Rhino.Command cmd, 0
   ' By preselecting the brep, the results of
   ' Split will be selected. So, get the selected
   ' objects and return them to the caller.
   DoBrepSplit = Rhino.SelectedObjects
   ' If any objects were selected before calling
   ' this function, re-select them
   If IsArray(saved) Then Rhino.SelectObjects(saved)
   ' Don't forget to turn redrawing back on
   Rhino.EnableRedraw True
End Function
The function above can be test using the following simple subroutine:
Sub TestSplitBrep
   Dim brep, cutter, pieces, i
   ' Pick the brep to split
   brep = Rhino.GetObject("Select surface or polysurface to split", 8 + 16)
   If IsNull(brep) Then Exit Sub
   ' Pick the cutting brep
   cutter = Rhino.GetObject("Select cutting or polysurface to split", 8 + 16)
   If IsNull(cutter) Then Exit Sub
   ' Call our special splitter
   pieces = DoBrepSplit(brep, cutter)
   If IsArray(pieces) Then
     For i = 0 To UBound(pieces)
       Rhino.Print pieces(i)
看到一个实例,居然正是我要找的,_SelID 选择物体 ID
GMT+8, 2026-7-1 15:30 , Processed in 0.098402 second(s), 23 queries , Gzip On.
