查看: 32888|回复: 10
[研发成果] 创意折叠椅子设计模仿(Rising Chair by Robert van Embricqs)
发表于 2016-11-16 09:51:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The Rising Chair emphasize the natural shape an object can made by transforming itself. Every piece of the chair has his own task to succeed in this transformation. It’s very easy to gather a huge collection of different chairs, throughout the years there has been a staggering abundance of them, in all shapes and sizes. But what fascinated me during my research was a simple question: to what degree is the object you're creating capable of dictating its own design? Is it even possible for an object to 'tell' for which form its best suited? And if so, what will the end result be?
Following this train of thought led me to discover several interesting options to create a new kind of chair.  The foundation of any chair is the flat surface you'll eventually sit down on. Using this notion as a starting point, I made several cuts in the flat surface and pulled up the different beam-like strands of cut surface. This created the preliminary but already distinct features of any chair: back, seat and legs. The rhythm of the wooden beams gives the chair an organic shape. The cuts are most visible when the chair is still down. But at that stage of the construction, I still didn't know what shape the chair would take in the end. This was determined by the various arches of the wooden beams the chair is made of. Folding the chair into its definitive form, as a creator, a special connection to the material was born.摘自http://www.robertvanembricqs.com/rising-chair
本设计是对Rising Chair的一个模仿。Robert van Embricqs有很多创意设计,如有兴趣请查看官网。
椅子.gh
20.06 KB, 下载次数: 124, 下载积分: 照度 -1 lux
售价: 2 lux照度  [记录]
参与人数 3强度 +9 照度 +19 收起 理由
Rrou + 3 + 2 感谢分享!
月之眼 + 3 + 2 感谢分享!
skywoolf + 3 + 15 感谢分享!
发表于 2016-11-16 15:30:01 | 只看该作者
之前也看过这个椅子,构思简洁巧妙。挺给力的~
看过大哥分享的帖子,让我对参数化有了另一种解释。只是大哥的帖子都有阅读权限,对于初级会员的我只能是远远地膜拜一下了。这个论坛算是我的启蒙老师。能收到大哥的回复,心理还是有点小激动。  详情 回复 发表于 2016-11-16 21:18
 楼主| 发表于 2016-11-16 21:18:44 | 只看该作者
过奖了!必要的权限可以维持新老会员之间的一种交流平衡。好的交流氛围还需要大家一起努力参与~ 放心,多参与多分享,权限很快能拿到~  详情 回复 发表于 2016-11-16 23:44
发表于 2016-11-16 23:44:34 | 只看该作者
tanxunwenti 发表于 2016-11-16 21:18
看过大哥分享的帖子,让我对参数化有了另一种解释。只是大哥的帖子都有阅读权限,对于初级会员的我只能是 ...
放心,多参与多分享,权限很快能拿到~
发表于 2016-11-18 10:35:28 | 只看该作者
感谢楼主分享!
很有意思的设计,“红点奖”呀~
领导给点实质性的奖励~~  详情 回复 发表于 2016-11-18 19:42
 楼主| 发表于 2016-11-18 19:42:24 | 只看该作者
Rrou 发表于 2016-11-18 10:35
感谢楼主分享!
很有意思的设计,“红点奖”呀~
领导给点实质性的奖励~~
发表于 2017-12-17 20:49:43 | 只看该作者
太厉害了,受打击了,我们这种学渣怎么可能解得出来这种题///
那个,看网上用KANGROO做的,坐等大神再解一个
发表于 2019-11-27 22:53:24 | 只看该作者
这个有趣呀,学习一下。。。
发表于 2024-10-10 19:01:46 | 只看该作者
照度是不是有毛病,文件没下载下来,重复点击还重复扣除,
发表于 2024-10-10 19:02:40 | 只看该作者
有毛病,什么问题?
发表于 2024-12-26 09:27:48 | 只看该作者
这个有趣呀,学习一下。。。
GMT+8, 2026-7-1 04:50 , Processed in 0.101132 second(s), 28 queries , Gzip On.
