查看: 10777|回复: 1
[GH插件] grasshopper中的vb编程问题求助
发表于 2022-10-18 10:44:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出现未声明onutil,可能因其保护级别而不可访问的错误
Private Sub RunScript(ByVal PenroseString As String, ByVal Length As Double, ByRef PenroseLines As Object)
    Dim Pt As New Point3d(0.0, 0.0, 0.0)
    Dim arrPoints As New List( Of Point3d )
    Dim V As New Vector3d(1.0, 0.0, 0.0)
    Dim PtStack As New List( Of Point3d )
    Dim VStack As New List( Of Vector3d )
    Dim count As Integer = PenroseString.Length
    Dim i As Integer
    Dim Rule As Char
    For i = 0 To count - 1
      Rule = PenroseString(i)
      If Rule = "+" Then
        V.Rotate(OnUtil.On_DEGREES_TO_RADIANS * (+36.0), OnUtil.On_zaxis)
      If Rule = "-" Then
        V.Rotate(OnUtil.On_DEGREES_TO_RADIANS * (-36.0), OnUtil.On_zaxis)
      End If(error(BC30451)未声明onutil,可能因其保护级别而不可访问)
      If Rule = "1" Then
        Dim newPt1 As New Point3d(Pt)
        arrPoints.Add(newPt1)
        Dim newPt2 As New Point3d
        newPt2 = Pt + (V * Length)
        arrPoints.Add(newPt2)
        Pt = newPt2
      If Rule = "[" Then
        Dim newPt As New Point3d(Pt)
        PtStack.Add(newPt)
        Dim newV As New Vector3d(V)
        VStack.Add(newV)
      If Rule = "]" Then
        Pt = PtStack(PtStack.Count() - 1)
        V = VStack(VStack.Count() - 1)
        PtStack.RemoveAt(PtStack.Count() - 1)
        VStack.RemoveAt(VStack.Count() - 1)
    Dim allLines As New List( Of Line )
    For i = 1 To arrPoints.Count() - 1 Step 2
      Dim line As New Line(arrPoints(i - 1), arrPoints(i))
      allLines.Add(line)
    PenroseLines = allLines
求求帮帮小弟了 快哭了
 楼主| 发表于 2022-10-18 15:28:51 | 只看该作者
顶一下!!!!!!!!!!
GMT+8, 2026-7-1 04:52 , Processed in 0.124669 second(s), 22 queries , Gzip On.
