查看: 49152|回复: 56
[VB & C#] 3d 凸包 ghx已传上
发表于 2010-1-21 03:02:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3000ms
扫描算法是网上的 请高人指点
基本上没有用处
算法相当蛮力
弄出几乎可能出现的所有的面 然后逐面进行判定
19个点就存在16*16*16=4096个面 判定4096次 很恐怖的
{:3_63:}
以前2d hull的算法也很糟糕 请高手指点
这里贴上2d hull的代码
Private Sub RunScript(ByVal x As List(Of On3dPoint), ByRef A As Object)
    'your code goes here…
    Dim list As  New List (Of On3dPoint)
    Dim firstPt As New On3dPoint(x(0))
    Dim j As Integer = 0
    For i As Integer = 1 To x.count - 1
      If x(i).x < firstPt.x Then
        firstPt = x(i)
        j = i
    list.Add(firstpt)
    Dim firstPt1 As New On3dPoint(firstpt)
    'first is correct
    Dim listPt As New List (Of On3dPoint)(x)
    listPt.RemoveRange(j, 1)
    Dim sign As Integer = 0
    While sign = 0
      'print(jj)
      For ii As Integer=0 To listpt.Count - 1
        If ispt(firstPt, listpt(ii), listpt, ii) = True Then
          If listpt(ii) = firstpt1 Then
            sign = 1
            Exit For
          Else
            print(ispt(firstPt, listpt(ii), listpt, ii))
            Dim newlistpt As New List (Of On3dPoint)(x)
            newlistpt = removeitem(firstpt, newlistpt)
            print(newlistpt.count)
            firstPt = listpt(ii)
            list.Add(firstpt)
            listpt = newlistpt
            Exit For
    End While
    a = list
  '<Custom additional code>
  Function ispt(first, second, list, i)
    Dim list1 As New list(Of On3dpoint)
    list1 = list
    Dim second1 As New On3dpoint
    second1 = second
    Dim vector As New On3dVector
    vector = first - second
    Dim v As New On3dVector(0, 0, 1)
    vector.Rotate(1.5708, v)
    Dim third As New list(Of On3dPoint)(list1)
    third.removerange(i, 1)
    Dim sign As Double = 0
    '____________________________________________
    For j As Integer=0 To third.count - 1
      Dim forth As New On3dVector
      forth = first - third(j)
      Dim v1 As New On3dVector(vector)
      Dim v2 As New On3dVector(forth)
      v1.unitize()
      v2.unitize()
      Dim dot As Double
      dot = OnUtil.ON_DotProduct(v1, v2)
      If (dot > 1) Then dot = 1
      If (dot < -1) Then dot = -1
      dot = math.Acos(dot)
      If dot < 1.571 Then
        sign = 1
        Exit For
    If sign = 0 Then
      ispt = True
    Else
      ispt = False
  End Function
  Function removeitem(item, list)
    Dim newlist As New list(Of On3dPoint)
    For i As Integer=0 To list.count - 1
      If  list(i) <> item Then
        newlist.add(list(i))
    removeitem = newlist
  End Function
效果视屏已传上
2d hull.part1.rar
480 KB, 下载次数: 58, 下载积分: 照度 -1 lux
2d hull.part2.rar
447.57 KB, 下载次数: 48, 下载积分: 照度 -1 lux
3dqhull.part1.rar
480 KB, 下载次数: 36, 下载积分: 照度 -1 lux
3dqhull.part2.rar
444.82 KB, 下载次数: 53, 下载积分: 照度 -1 lux
售价: 5 lux照度  [记录]
3dhull.ghx
109.86 KB, 下载次数: 37, 下载积分: 照度 -1 lux
售价: 20 lux照度  [记录]
3dhull的扫描算法.txt
9.93 KB, 下载次数: 45, 下载积分: 照度 -1 lux
参与人数 1强度 +3 照度 +50 收起 理由
skywoolf + 3 + 50 很有启发
收藏收藏3 分享分享
 楼主| 发表于 2010-1-21 03:07:29 | 只看该作者
最快的算法是通过求向量交角来判定边界 我用的是数点Function ispt(first, second, list, i)
慢了一个数量级 有没有哪位同学知道如何区分交角是顺时针还是逆时针
发表于 2010-1-21 09:25:15 | 只看该作者
有点理解紫暗说的算法问题了,期待高手出现.
发表于 2010-1-21 11:26:39 | 只看该作者
囧,你不是做出了个,3D 的么,怎么不贴下,也许大家写不会,要改的话就容易多了,这样也容易多了吧
 楼主| 发表于 2010-1-21 15:45:25 | 只看该作者
4# nice
讨论算法的话并不需要代码吧
网上有C++的扫描算法 但是移植到gh里还是有些困难的
我的算法很简单 就是判定所有存在的面是否符合凸包的要求
计算几何上的逐个添加点的算法 不知有人看懂了没有
讨论算法用伪码就行了
这是3d hull的伪码
输入 L(3d 点)
for (i=0 ,i<L.length-2,i++){
for (j=i ,i<L.length-1,j++){
for (k=j ,i<L.length-,k++){
if(L(i),L(j),L(k)组成的面否符合hull的边界条件){
添加L(i),L(j),L(k)组成的面到集合M中
算法太囧 不好意思贴出来
发表于 2010-1-21 16:38:37 | 只看该作者
O'Rourke (1998) gives a robust two-dimensional implementation as well as an  three-dimensional implementation. Qhull works efficiently in 2 to 8 dimensions (Barber et al. 1996).
发表于 2010-1-21 23:09:03 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2010-1-21 23:18:33 | 只看该作者
7# gzblake
其他算发有退化的bug的 2级循环算法是很烂
一般都是通过 向量朝一个方向的转角的大小 找点
是很笨的方法 但bug最少
你可以改成求出(已知的一条边和 (这条边的末端点与其它点的连线)的交角集合)中的最小值来找点
发表于 2010-1-21 23:37:57 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2010-1-22 09:54:56 | 只看该作者
9# gzblake
2d凸包不算退化情况的话 是这样的 思考怎样用一根线箍住扎在木板上的一些钉子就就明白了
发表于 2010-1-22 10:12:15 | 只看该作者
{:3_51:}这个图表达的真清晰~
发表于 2010-1-22 15:17:44 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-1-22 15:39:16 | 只看该作者
买来看看{:3_46:}
 楼主| 发表于 2010-1-22 17:08:49 | 只看该作者
修改了一个bug 把ghx文件传上来了
会C++的大歌帮忙指点下扫描法吧
发表于 2010-1-22 22:37:57 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-1-26 01:39:49 | 只看该作者
5# panhao1
思路很清晰哈
哦 两级嵌套循环…感觉貌似冗余度有点大………
参与人数 1照度 -5 收起 理由
skywoolf -5 灌水内容
发表于 2010-1-26 20:53:19 | 只看该作者
感觉是个好东西~
发表于 2010-1-28 22:53:11 | 只看该作者
真的很牛····
发表于 2010-1-29 13:44:55 | 只看该作者
凸包是什么呢,我觉得这个还是真不错
发表于 2010-2-4 01:49:31 | 只看该作者
很棒啊!! 学习,学习!
GMT+8, 2026-7-4 15:06 , Processed in 0.090971 second(s), 28 queries , Gzip On.
